Guest wireless login problem
rtrees
Level 4
Level 4
I have a guest wireless network through my controllers and am using WCS to manage the controllers. The problem I am seeing is when users are prompted to log in to the guest network they can either use the guest user account the lobby ambassador has setup or they can use an AD account if they have one. I have looked through my configuration and must be missing something because everywhere I look says it should be using "default internal" for the authentication. Any ideas where I should be looking that I'm not? Thanks.
15 Replies 15
Thanks everyone for the suggestion, this sounds like the best option we have but it would be nice if Cisco gave the option.
