VLAN ISSUE
I have 2100 WLAN with cisco catalyst 3750 switch. I have two vlan on the switch which are 10.x.x.x and 192.168.x.x. The 10.xxx network are on wireless client nd the 192.168.x.x are on the wire client.I can only ping there default ip addr of each vlan. But i can not go across to each vlan.
Scott Fella
Do you have routing configured between the two vlans?
-Scott
