guest wlan
goncalo.girao
Almost there.
Scenario:
2504 wlc
Aps 1140
Port 1 lan radius all ok
Port 2 defined for guest wlan directed attach no isp router dhcp
1 utp cable on router acquire ip address
On guest wlan no ip address is given i think i tried every combinations
Any help?
17 Replies 17
Now I have it! But still have a problem..
As the internal dhcp (WLC) is on same subnet the guest WLan has the same permissions... Humm
I tried to change the scope of the dhcp, no success because default Gateway is on primary LAN
When you create an interface, you need to have two separate vlans and subnets. The problem why you have an ip conflict is because you are trying to separate internal and guest which is on its own vlan/subnet. This can't be done. You need to have two separate vlans and your wlc needs to be connected to a trunk port.
-Scott
Now I have a Trunk ( I have HP  so is Tagged) for the Guest VLAN. I can have ip address from wlc DHCP and evev ping this interface IP address. But i Still cant reach my ISP Default gateway (created for this Guest WLan) on same VLAN Trunk.
