HA BOX availability monitoring
Victoro151207
Hi All,
Is it possible to monitor HA box WLC availability through SNMP?
What is the best practice to monitor this HA standby controller? As on config guide it said it is not possible to access standbyhot controller through GUI, PRime infra, or telnet.. Only can use console.
Victor
Yahya Jaber
Hi.
"Note: Once SSO is enabled, the Standby WLC can be accessed via console connection, SSH/Telnet on service port, and SSH on the redundant management interface"
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080bd3504.shtml
for monitoring in prime i found this link:
http://www.cisco.com/en/US/docs/net_mgmt/prime/infrastructure/1.2/user/guide/chgdevconfig.html
hope this helps
Victoro151207
Hi Yahya,
Thanks for your reply,
Just curious if HA box can send snmp to client monitoring tools for monitoring power supply and all hardware things inside the box, also for example the availability of trunk port to switches
Victor
