Help! AP 1262 cannot Join Cisco WLC 4402
kellyezekwe
We have two cisco 1262 AP and a 4402 WLC, the AP cannot join the WLC.
The AP gets the address from dchp
I cannot ping the AP address from the WLC, but i can ping the default gateway and other VLAN addresses.
I already read the info on the this link :
http://www.cisco.com/en/US/products/ps6366/products_tech_note09186a00808f8599.shtml
Still our AP cannot join the WLC no matter what i have tried.
Can anyone help with this problem?
Setup
- VLAN setup on a Cisco 3560 48 port poe Switch
- tunk configured btwn the Gi Interface and the Management physical port
- WLC mode is configured for Layer 3
- AP Manager and Management are in the same Subnet
- Option 43 is configured for the with the AP Manager's  IP address
- Opotion 60 is also configured with  AP Manager's  IP address
- the port connected to the APs are in the AP Manager VLAN
Please help.
Thanks!
Leo Laohoo
Duplicate post.
AP2c54.2d9e.02de>sho inventory
AP2c54.2d9e.02de>sho ver
Cisco IOS Software, C1260 Software (AP3G1-RCVK9W8-M), Version 12.4(23c)JA3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 18-Oct-11 15:02 by prod_rel_team
ROM: Bootstrap program is C1260 boot loader
BOOTLDR: C1260 Boot Loader (AP3G1-BOOT-M) Version 12.4(23c)JA, RELEASE SOFTWARE (fc3)
AP2c54.2d9e.02de uptime is 30 minutes
System image file is "flash:/ap3g1-rcvk9w8-mx/ap3g1-rcvk9w8-mx"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1262N-N-K9    (PowerPC460exr) processor (revision A0) with 81910K/49152K bytes of memory.
Processor board ID FTX1616E48X
PowerPC460exr CPU at 666Mhz, revision number 0x18A8
Last reset from power-on
LWAPP image version 7.0.112.74
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 2C:54:2D:9E:02:DE
Part Number                          : 73-12175-05
PCA Assembly Number                  : 800-32268-05
PCA Revision Number                  : A0
PCB Serial Number                    : FOC16140D19
Top Assembly Part Number             : 800-33866-01
Top Assembly Serial Number           : FTX1616E48X
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1262N-N-K9
Configuration register is 0xF
AP2c54.2d9e.02de>
1260 AP supported from 7.0.116.0 WLC code.
