Help using python for updating an access point management interface
Captain2
Level 2
Level 2
Dear Members,
Trying to update an access point device management interface by using the function
import meraki
dashboard = meraki.DashboardAPI(api_key="my_api_key")
payload = {"wan1": {
"usingStaticIp": False,
"vlan": "100"
result = dashboard.devices.updateDeviceManagementInterface(serial_key, payload)
print(result)
The result is the following output:
updateDeviceManagementInterface() takes 2 positional arguments but 3 were given
Process finished with exit code 0
When running the function below
result = dashboard.devices.getDeviceManagementInterface(serial_key)
print("Device Management Interface:")
print(result)
{'wan1': {'usingStaticIp': False, 'vlan': None}}
It looks like I am using the correct structure but it doesn't work.
This are the arguments that the function expects:
Can you please help me find and correct it?
Best Regards,
ww^
Meraki Community All-Star
import meraki
serial_key= "xxxxxxx"
payload = {
"vlan": "100"
result = dashboard.devices.updateDeviceManagementInterface(serial_key, wan1=payload)
print(result)
Cant tell exactly, but it thinks the payload= are 2 args now and with the serial that makes 3
But If you move wan1= to the result it works.
5 Replies 5
ww^
Try add the
"wanEnabled": "not configured",
Added it and getting the same message:
ww^
import meraki
payload = {
"vlan": "100"
print(result)
Philip D'Ath
There seems to be a closing brace missing.
"vlan": "100"
Should probably be:
"vlan": "100"}
Many thanks, that was it!
