Help with Wireless Phone Setup
kellyrudnick
Level 2
Level 2
I have:
12 - Cisco 7921 phones
1 - (Offsite, within our WAN)
10 - 1242 APs connected to 3560s
I need to connect the phones in a way that provides as much security as possible with minimal latency. What configuration and implementation do you recommend that utilizes the ACS as a central point of authentication.
migilles
Most secure 802.1x authentication type supported is EAP-TLS, but requires management of certificates. For fast roaming, you can use CCKM, which is supported with WPA(TKIP). If not wanting to use EAP-TLS, then can use EAP-FAST or PEAP.
See the 7921G Deployment Guide for more info.
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7921g/6_0/english/deployment/guide/7921dply.pdf
This is my first 7921G pone setup and I need to know or at least find a guide how to load certificates on a 7921 phone.
Any advice
I posted this on your other thread, but here is a link:
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7921g/7_0/english/administration/guide/7921cfgu.html#wp1376129
-Scott
