Hotspot Solution
sroberts
Frequent Visitor
Frequent Visitor
Hello all,
I'm looking for a hotspot solution other than the NAC guest server that will integrate with the WLC.
We need an enterprise solution that will allow us to authenticate the users, allow us to do billing, allow us to restrict access time, and more..
Is there a cisco solution other than the NAC server or any other 3rd party solution that can integrate with the WLC?
thanks in advance
Scott Fella
You can look into ZoneCD, but will have to be placed in-band. There are others out there that are not free that you can use.
Here are some others:
http://www.antamedia.com/
https://secure.wirelessorbit.com//
http://www.wifi-radius.com/
http://www.alepo.com/hotspot-billing-software.shtml
-Scott
pemasirid
Level 6
Level 6
That is already EOS!
-Scott
