How, Captive Portal (Web-Login) along with Dynamic VLAN assignment
n.poongsawad
Hi mate,
I'm stucking cnfg a WLAN which could do Web-Login (no L2 security). But also need to recieve the RADIUS return attributes to change its VLAN that map with its proper right.
Can I do by native Web-Login with additional WLAN>Advance>Allow AAA overide? That's all?
Please help.
Nipat.p
Scott Fella
Well here is the issue when changing the vlan for a WebAuth client. The WebAuth client first needs to obtain an IP address in order to even get the portal page to login. So when a WebAuth client already has an IP address and them you change their vlan assignment, well they now have an IP address on the wrong vlan.
So doing this with a WebAuth client will not work. This only works with climbers that radius looks at the credentials and the radius policies prior to the client obtaining an IP address.
-Scott
Scott,
Thus, saying that, ONLY ONE WAY out to do Dynamic VLAN Assignment via RADIUS is L2 8021x ?
Nipat.p
That is correct.
-Scott
You can checkout this one https://youtu.be/bzoTvgYQoNQ
VLAN steering (or dynamic VLAN assignment) over captive portal allows networks to steer users to different VLANs based on their profiles (supports both wireless and wired networks). This handy features puts all users into default VLAN at initial connect, prompts them with a login portal for easy ...
