How do I move maps from Cisco WCS v.5 to WCS v.7?
rayost
How do I export maps from Cisco WCS v.5.1 and import them in WCS v.7?
The old WCS (v.5) is installed on Red Hat Enterprise Linux and the new WCS (v.7) is installed on a Windows 2003 server.
Are maps in .tar format? I could not find any tar files on the old WCS server that looked like maps.
Thanks!
Nicolas Darchis
1 way is : Upgrade your Red Hat WCS to 7.x version, do a backup of the database and import it on the Windows WCS.
The other way is "Monitor->Maps". Select the maps you are interested in and in the combobox, chose "export maps".
Hope it helps.
Nicolas
5 Replies 5
Nicolas Darchis
Hope it helps.
Nicolas
Thanks for the reply Nicolas Darchis.
So I have to upgrade in order to obtain the maps? Since the "export maps" function is not available in v. 5.
I didn't remember in which release they introduced it but then yes, you upgrade your WCS5 to 7 and you can export the maps easily
sridhkri
For WCS 7.0 release will support up to (N-2) release (i.e 6.0 and 5.2) only. 7.0 will not support in 5.1 release so you have to upgrade to any one of the release like 6.0.or 5.2 ,then do export option and import it to 7.0 release.
Thanks and Regards
Sridharank
rayost
Backup of the WCS, restore on the new server on version 5.2, then upgraded to v.7
