How do I view the serial number of an AP1310 using GUI?
yijiang
Hi everyone,
    I have a problem with an AP1310 which may need me to open a case for RMA. is there any way I can view the serial number using the GUI since the AP is already installed on a high mast but I didn't enable telnet on that?
    Appreciate your answer
hirenparekh12
Hi Vijiang,
After login GUI just go to System software & you got all the required details
