How do we see DSCP marking in Wireless
Edward.g
Hi all ,
My company has just implemented wireless QoS . Critical services has been applied as Platinum .Now , we need to test if the DSCP markings are per expectations or not . Like : DSCP "EF" and "AF" markings.
I have been searching cisco documents from sometime but no luck . Can anyone help me out here , I need to see the DCSP EF and AF markings from wireless perspective .
Thanks in advance .
Edward
5 Replies 5
RichardAtkin
Level 3
Level 3
https://www.wireshark.org/
^^ This is the only way to be 100% sure.
Alternatively, if you mean you want to check out the config assocaited with QoS mappings, see here for details;
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/quality_of_service.html
Thank you Richard
As mentioned ,I guess wireshark is the only way
Ed
Rasika Nayanajith
Hi Edward,
You have to check end-to-end QoS settings to ensure it is preserved across the path. Below may given an idea
https://mrncciew.com/2013/01/08/byod-with-qos/
Over the air capture is required to see what QoS value you seen in wireless frames.
If you get 5520/8540 with AireOS 8.2.x or above, you can get DSCP value as part of netflow data. So you can monitor that field specifically.
https://mrncciew.com/2018/02/20/wlc-netflow-with-extrahop/
From wired side, you can do that using captures & also using a netflow analysis tool
Rasika
*** Pls rate all useful responses ***
Hi Rasika ,
Thank you for the suggestions . My WLC is 5508 with Version 8.3.143.0
If Netflow is useful here , we do have Cisco Stealthwatch , will this be of any help to get the wireless DSCP for the marked traffic ?
Ed
Hi Ed,
Though 5508 does not support enhanced netflow, it got IP_DSCP as one field out of 10 fields in its netflow records.
https://mrncciew.com/2016/12/19/wlc-netflow-with-aireos-8-2/
Not sure stealthwatch support that flow format & you can get it analyzed. Give it a try & see
Rasika
