How does WLC block traffic between client and difference APs .
069521139
Frequent Visitor
Frequent Visitor
I configured P2P blocking with Flex Connect mode .
Client in same Aps is work but client in difference Aps still send traffic between client.
Can you give me any idea to help to troubleshoot this issue?
Regards.
Wongsakorn.
Rasika Nayanajith
I believe this is how it works.
Which software code you running on your WLC
Rasika
I have WLC8510 with software 8.2 .
I think flexconnect with p2p targets only clients connected to the same AP.
Wongsakorn,
Hi Wongsakorn,
P2P blocking does not seem to work in the case of flexconnect AP's when clients are connected to different AP's. As per the configuration guide, we can block P2P between clients on different APs by the use of FlexConnect ACL when the WLAN is Central Switching:
http://www.cisco.com/c/en/us/td/docs/wireless/controller/8-2/config-guide/b_cg82/b_cg82_chapter_01010001.html?bookSearch=true
"Unified solution for central switching clients supports peer-to-peer blocking
for clients associated with different APs. However, this solution targets only
clients connected to the same AP. FlexConnect ACLs can be used as a workaround
for this limitation.
The same solution should work for flex local switching as well. You can configure VLAN ACL on the flex group for this.
Best Regards,
WiFi Trainers (www.wifitrainers.com)
Your one stop solution for all your wireless training needs!
******** Please rate if useful *********
