How monitor any change of a WLAN in WLC 5508?
cabonillaa
Hi everyone,
I'm trying to monitor any change of a WLAN such as create, delete or modify. But, the System Message Guide doesn't have any message related to this topic when I turn syslog on.
Do you know if there's any configuration or additional software which allows to monitor these sort of changes?
George Stefanick
Thats a great question. The WLC syslog is pretty cryptic. The WLC really uses traps to registart most active events. It sounds like you are looking for some level of accounting. Do you have a radius server or TACACS ?
I dont know if syslog will show this ..
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Thank you George for your response,
I just install a Radius server. Do you know if it's possible to configure a monitor for WLAN?
