How to change RTS Threshold in Wireless LAN Controllers
romeyrome
Level 4
Level 4
I've read some opinions that lowering the RTS threshold can help in some noisy wireless environments. I have found how this can be done on standalone APs but cant seem to implement the change on a WLC 2112. Does anyone know if this is possible and how to do it. Thanks in advance.
romeyrome
Level 4
Level 4
According to Cisco this feature does not exist in controller-based environments. This is what I get when I try to configure the RTS setting from the CLI:
(Cisco Controller) config>slot 1 rts threshold 1024
enable rts/cts only available for Mesh APs.
I have submitted a feature request so we'll see what happens. Thanks for reading and please let me know if you have any pertinent information.
Bump.  Any update to this?
CCNP - Wireless
CWNE #136
Mesh aps are in wlc environment. The message you get says rts config only available in special kind of APs, not normal APs. But they are working with wlc environment.
Rating useful replies is more useful than saying "Thank you"
