How to configure IP addresses in cisco packet tracer?
ghulammurtaz679
Hello I am working with Cisco packet tracer. I have two laptops connected to a wireless router with IP addresses assigned using DHCP. The router's Internet IP address is 10.1.0.0 and the LAN address is 192.168.0.1. I have an image below to for visual
 Here Wireless Router0 is the one with the IP addresses I specified above. Also on Router0 I have set the IP address on the port on which Switch0 is connected to 10.1.0.0. I want to make a ping request to PC0 from Laptop0 . When I do, I get request timeouts, that is 100% packet loss. I want to know also that how would I access Laptop0 from PC0. Thanks
Martin L
how far can u go? trace fails at where ?  Few things to check like default gateway, vlan, etc.
it will be faster if you attach your PT file here (zip format)
Regards, ML
**Please Rate All Helpful Responses **
