How to create a copy of a WLAN?
timovirt1
Is there a single copy command to copy the details on one WLAN to another (new one)?
Currently we have a use case to create multiple WLANs using the same SSID.
In such cases, the command to show details for a specific WLAN is  :  show WLAN <ID> . This shows about 120 properties associated with a WLAN.
So to configure the same properties for the new WLAN except for the ID and profile name, we will have to issue about 120 config commands.  So wanted to know, whether there is a possibility to copy the parameters associated with a WLAN to another using a single command?
Can that be done using WLC or Cisco Prime?
Any help and pointers are appreciated
Timo
tony.sangha
There is no copy command as such, however you can export the WLC config file and copy the command structure from that. To perform an export, you will require a FTP or TFTP server running on a laptop/PC.
1. SSH onto WLC and execute the following commands:
transfer upload username cisco
transfer upoad password cisco
transfer upload mode ftp
transfer upload filename WLC-BACKUP
transfer upload serverip XXX.XXX.XXX.XXX
transfer upload datatype config
transfer upload path ./
transfer download port 21
Once you have the configuration file, you can open it with notepad or any other text editor and look for the commands that begin with config wlan. Copy and manipulate the commands as required.
**Please rate if this post was helpful. Thank you**
