How to disable APs on Wireless Lan Controller
machomn
Hello Experts,
I'm newbie on network environment. I have Cisco 2504 and 20 APs connected to cisco wireless lan controller. I need temporary disable my 3 APs. How to solve it?
Experts please help me.
2 Accepted Solutions
ammahend
see the attachment.
-hope this helps-
Scott Fella
You can also issue a config AP disable <AP name> or shut the switch port down if the AP is getting PoE from the port.
-Scott
-Scott
ammahend
see the attachment.
-hope this helps-
Scott Fella
-Scott
-Scott
machomn
Thank you very much.
You guys helped for me.
