How to disable LAP syslog?
Hello all.
I'm using a 5508 WLC with a couple of LAP3502 APs.
The WLC itself is logging to a syslog server.
I didn't configure anything on the individual APs, but still I see them announced at the syslog server.
Now I'd like to disable AP syslogging: how do I do it?
Or better: would it be OK disabling syslogging from individual APs? Could I be missing some informations, or would it all be sent to the WLC, which is then writing logs to my syslog server?
Thanks and kind regards,
F:
18 Replies 18
Why not test it on one ap and see if the ap still logs traps or not. This way you not wasting any time to enter te command if it the wlc still sends ap traps.
Scott Fella
Sent from my iPhone
-Scott
did that work for you?
-Scott
Hello Scott,
yes it did work perfectly: no more syslog from those LAPs reaching my syslog server.
Thanks for your precious help!
F.
No problem and glad that worked.
Scott Fella
Sent from my iPhone
-Scott
