How to downgrade WCS?
huangedmc
Level 3
Level 3
We plan on upgrading our WCS from 5.0.56.0 to 5.2.130.0, to support the WLC's that run 5.2.178.
We know how to upgrade, but would like to know how to downgrade to a previous version in case we need to rollback.
The config guide only tells you how to upgrade:
http://www.cisco.com/en/US/docs/wireless/wcs/5.2/configuration/guide/5_2main.html#wp1074975
It doesn't mention anything about downgrade / rollback procedure...
Take a backup of database on 5.0.56.0. In case you need to go back, uninstall the new version, then perform a clean install of 5.0.56.0 and restore the backup.
Pushkar
Pushkar
