How to get a persistent entPhysicalIndex for cellular ( 1117-LTE )
msnelders
Hi all,
Iam monitoring the cellular signal strenght and current band connected 24x7 of our customers.
We do this with SNMP and the application Paessler PRTG Network Monitor.
The OID`s i use to monitor for example the RSSI, RSRP and RSRQ are:
RSSI: 1.3.6.1.4.1.9.9.661.1.3.4.1.1.1.7006
RSRP: 1.3.6.1.4.1.9.9.817.1.1.1.1.1.1.7006
RSRQ: 1.3.6.1.4.1.9.9.817.1.1.1.1.1.2.7006
I found those OID`s with the CISCO-WAN-3G-MIB.mib
As you can see the last 4 numbers are always the same because they seem to refer to my cellular modem wich has a entPhysicalIndex of 7006 by default.
The problem iam facing is that whenever the router or cellular modem reboots that vallue will add up by +1 so it will be 7007 after a reload.
My monitoring tool PRTG will then generate an error message with: "No Such Instance" because the OID has been changed.
Is there a way to get a persistent entPhysicalIndex for my cellular modem so the OID will not change after a reload ?
I already tried snmp ifindex persist on my cellular0/2/0 interface but that doesnt help
Thanks in advance!
Kind regards,
Michael
vasyu
So have you solved this problem? Thanks!
msnelders
No, i still dont know if its possible to make it persistent.
At the moment iam using a script to find the correct index with every scan interval in PRTG
