How to improve CURWB speed?
  CURWB1 CURWB2
Antenna IW-ANT-OMH-2567-N IW-ANT-OMH-2567-N
PID IW9167EH IW9167EH
IP ADDR 192.168.1.10 192.168.1.11
MODE MESH END MESH POINT
AP1# show dot11Radio 1 config
Interface:              enabled
Mode:                   fixed infrastructure
Frequency:              5180 MHz
Channel:                36
Channel width:          80 MHz
Antenna number:         4
TX power level:         auto
TX power:               20 dBm
Antenna gain:           unselected
Maximum tx mcs:         11
High-efficiency:        enabled
Maximum tx nss:         4
RTS protection:         disabled
guard-interval:         800 ns
ampdu max length:       255
distance:               1000 m
The ampdu Tx
priority 0:             enabled
priority 1:             enabled
priority 2:             enabled
priority 3:             enabled
priority 4:             enabled
priority 5:             enabled
priority 6:             disabled
priority 7:             disabled
Enhanced Distributed Channel Access (EDCA) configuration
vo: aifs=1 cw_min=2 cw_max=3 txop=15
vi: aifs=1 cw_min=3 cw_max=4 txop=31
be: aifs=3 cw_min=4 cw_max=6 txop=31
bk: aifs=7 cw_min=3 cw_max=4 txop=0
Passphrase:             CiscoURWB
AES encryption:         enabled
AES key-control:        disabled
Key rotation:           disabled
Key rotation timeout:   0(second)
We put two CURWB APs on a single desk and connected them with MESH.
Then we connected a PC to the DC injector and measured the network with PC to PC and iperf.
But we are not satisfied with the speed.
I need some advice to improve the speed.
Leo Laohoo
What speed are you getting?
What firmware are the two APs on?
How far (distance-wise) are the two APs situation from each other?
There is an APs on my desk. The distance to the AP is within 1 meter.
The speed is sometimes 100 Mbps and on average 200 Mbps.
I0T
  • The distance between the APs with a Tx power of 20 dBm is too short, which can cause overmodulation. Set the Tx power to the minimum for testing purposes.
  • Ensure that the antenna gain is configured correctly (7 dBi for 5 GHz).
  • Make sure the distance between antennas connected to the same AP is at least 20 cm
