how to remove ap from controller
hugh.lancaster
Level 3
Level 3
I cannot find where to reboot an individual AP? I have clients that are connect to an AP upstairs and the signal is weak. I have an AP located in the same room as AP but clients do not connect. Where can i reboot the AP that I do not want clients to connnect to. thanks
Reset AP, will reboot the AP.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Scott Fella
From the GUI, click on the wireless tab and then click on the ap you wish to reboot.  On the bottom of the ap general page, you will see a reboot ap button.  You would click on that to reboot the AP.  You probably need to look at why the ap's can't connect to that ap.
-Scott
Yeah that is why I want to reboot the indivdual AP. I am trying to determine why clients are not connecting to the closest device.. Anyhow, I don't have the option to reboot. I see "reset AP now"- that completes a hardware reset. Right?
HTH,
Steve
HTH,
Steve
Thanks for clarifying. It worked
