How to reset AP1100 to factory default
jlawan
Got a refurbished AP1100, had an IP which is not the default IP on the AP, anyone knows how to reset it it to the factory default? Tried pressing the mode button, but still cannot access the AP. FYI- there is no console or serial port on the AP unlike the AP350.
Thanks.
rsahney
hi,
You need to hold the mode button for about 30 seconds, the light will turn to red and then change to amber and back to green .....
BINGO .. good to go ..
my $0.0002 ;-)
