09-29-2010 10:52 AM - edited 07-03-2021 07:14 PM
What is the easiest way to track down a rogue AP to a switch port so that I can disable it? We have WISM and I we see the rogue and that its on our wired network. I could not found the macs that was associate with the rogue AP on our switches. I found the AP that reported the rogue AP and I know which switch that AP is connected to but I cannot find the mac.
09-29-2010 02:03 PM
If you have WCS the newer version does rouge on switch tracing for you... Have you played with that ?
09-30-2010 04:37 AM
I tried but I get an error stating that it cannot be performed because CDP is not enabled on the controller, even though it is enabled. So I am not sure why this is.
10-02-2010 11:41 PM
When it says controller, it may mean switch. Is CDP enabled on your switches?
10-04-2010 05:08 AM
yes we have cdp on all our switches
10-04-2010 05:29 AM
Are there rogue clients connected to the rogue access point? And, are they generating traffic?
10-04-2010 08:26 AM
yes on both questions
