09-20-2013 09:57 PM - edited 07-04-2021 12:54 AM
Hey, I just reached the Cisco AP(AIR-LAP1242AG-C-K9) recent days, and found that the AP are used before via a wireless controller, which means it is a light AP. and now i want to change it to be a weight one. because i want to use it in my office without the controller.
But a issue occured during the operation. i connected my pc to the AP via console, and CRT cannot work when i start connection.i can't control the AP.(the cable is ok because i used it to configure a switch few minutes ago.)I don't know why. so do you know any other ideas about this problem. or realise my intention just like the topic.
Solved! Go to Solution.
09-21-2013 07:06 AM
Here are some ways to convert without console
Using a TFTP Server to Return to a Previous Release
http://www.cisco.com/en/US/docs/wireless/access_point/conversion/lwapp/upgrade/guide/lwapnote.html#wp160918
https://supportforums.cisco.com/docs/DOC-18268
http://www.youtube.com/watch?v=QQ_NuxdRhQ4
https://supportforums.cisco.com/docs/DOC-14960
09-21-2013 07:03 AM
Make sure flow control is disabled. There is a difference when connecting to a switch or router than a wireless device.
09-21-2013 07:06 AM
12-11-2013 11:54 PM
thank you. i found the reason why i cannot use the console cable to finish the conversion.
