hreap vlan mapping issues
osvaldo Alcala
Frequent Visitor
Frequent Visitor
wlc 5508 code 7.0.220.0
AIR-CAP3502E-N-K9
ap mode: hreap
vlan mapping native 30
vlan ssid  x 310.
each time that for what ever reason my access point goes down(not that my access point resets by itself, if i have to move it), the setting in the vlan mapping  resets to  whatever my native vlan is, in this case 30
that is native vlan 30
ssid x vlan 30
any idea.
Stephen Rodriguez
Do you have multiple WLC?  if you do, the WLAN's need to be in the same order.  If you have HREAP Groups configured, they need to match as well.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
on
just one controller just one ssid no hreap groups or ap groups
it could be
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtw92394&from=summary
but it is marked Unreproduceable.  You might try upgrading to the latest 7.2 code if you don't have 'legacy' AP.
HTH,
Steve
HTH,
Steve
