Identify Wireless Antenna
mloraditch
Meraki Community All-Star
We have not encountered the antenna in the attached picture before and it doesn't appear to be from Cisco as it's not on the antenna product page. Does anyone know what it is or where it could be purchased?
Thanks!
If you found this post helpful, please give it a thumbs up. If my answer solves your problem please click Accept as Solution so others can benefit from it.
scottmac
Level 11
Level 11
I don't know the maker or model number, but it's almost certainly an omni, probably 5db or less; probably ~2-3dbi unless there's a hidden power wire.
It's just in a decorative radome (the cone-shaped shell around the antenna element).
Google on "wifi antenna" and you'll get a fairly long list of suppliers.
Good Luck
I checked a few web sites (Sparco, L-Com, TerraWave, etc.) and could not see a direct match.
I can tell you what the IP address of the AP probably is, though!
mloraditch
thanks everyone for your help!
