Interference cause by Active Rogue APs
Rosa Ladeira
Level 7
Level 7
Controller AIR-WLC2112-K9 shows on its Monitor -> Summary page:
Rogue Summary
Active Rogue APsDetail
Active Rogue ClientsDetail
Adhoc Rogues
Is it possible to configue controller in order to avoid interference from Acitve / Adhoc ?
Leo Laohoo
Yes and no.
The WLC will detect the rogue.  That's fine.  If TPC and DCA is enabled, then the WLC will also determine how strong the rogue AP's signals are and change the channel and/or transmit power accordingly.
