Internal DHCP not working for wireless Clients
gudmundurk
I'm in the process of installing a WLC but am having trouble with the internal DHCP server, I am able to associate but am not assigned an IP address, this is the configuration :
Client interface :
Interface Name................................... XXXXXXXX
MAC Address...................................... 00:1d:45:5e:52:27
IP Address....................................... 192.168.34.1
IP Netmask....................................... 255.255.255.0
IP Gateway....................................... 192.168.34.254
VLAN............................................. 331
Quarantine-vlan.................................. no
Active Physical Port............................. LAG (29)
Primary Physical Port............................ LAG (29)
Backup Physical Port............................. Unconfigured
Primary DHCP Server.............................. 10.100.8.1
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... No
Guest Interface.................................. No
DHCP pool :
Dhcp Scope Info
Scope: XXXXXX
Enabled.......................................... Yes
Lease Time....................................... 14400 (4 hours )
Pool Start....................................... 192.168.34.2
Pool End......................................... 192.168.34.200
Network.......................................... 192.168.34.0
Netmask.......................................... 255.255.255.0
Default Routers.................................. 192.168.34.254 0.0.0.0 0.0.0.0
DNS Domain.......................................
DNS.............................................. 212.30.200.200 212.30.200.199 0.0.0.0
Netbios Name Servers............................. 0.0.0.0 0.0.0.0 0.0.0.0
The Vlan interface points at the IP address of the Management interface.
Version :
Product Version.................................. 4.2.61.0
RTOS Version..................................... 4.2.61.0
Bootloader Version............................... 4.2.61.0
Anyone see what I'm missing ?
gudmundurk
If anyone else is having this problem, downgrade your WLC to 4.1.185.0, works like a charm after that.
same problem here,
thanks
