05-30-2007 02:49 PM - edited 07-03-2021 02:08 PM
I am testing 4.1 on one contoller but I am having issues roaming from a 4.1 controlled AP to a 4.0 controlled AP.
Should I be able to do this?
If I cant how can I test new code ?
05-30-2007 07:47 PM
Hi Friend,
I believe mobility group domain name is same and you might have configured both the controllers with mobility group config.
Can you check with "sh mobility sum" and confirm the status of your mobility group.
Actually it is good to have same image train on all the controllers in same mobility group.
Ankur
*Pls rate all helpfull post
05-31-2007 08:12 AM
I did the sh mobility summ command and I see all of my controllers in mobility group.
I know it a good idea ro have all contollers on the same version. I usually change the AP/controller code un my admin building first for a few weeks to test before I deploy to the hospital to make sure I am not deploying a code that could effect patient care.
any other ideas ?
