Is it better to use dedicated monitor-mode wIPS access points?
Is it better to use dedicated monitor-mode wIPS access points or shared-user-serving, local-mode access points with clean ir and WIPS this is possible?
Stephen Rodriguez
It all depends on what you are looking to do, and how much is in the budget.
IMO, dedicated MM AP will serve you better, but then that AP is not useable for clients(hence the budget comment).
Cheers,
Steve
Please remember to rate helpful posts
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
