is there a ROMMOM sw downloading Cisco AP-4800-K9?
Dan4171
I facing an issue upgrading an AP4800. I don't like the version is too old to connect with the Controller or something more rudimentary. The controller is a 3800 ME 10.151. The Ap4800 is running 8.7.x.
I can get even to ping. Tried multiple ways with trunk, changing native vlan, etc using cross connect with a PC, etc, etc. PC can ping the AP but the AP won't ping the PC.
My conclusion I'm missing something very basic or this device may have HW issue or a corrupted SW. During my troubleshooting I found the error below while the AP is booting up (u-boot phase)
<<<SF: Detected N25Q32A with page size 64 KiB, total 4 MiB
Checking image signing.
Image signing verification success, continue to run...
Loading Marvel PHY firmware...
Ethernet transceiver PHY firmware download started:
Error: Download failed, PHY is not in waiting on download mode. Expected 0x000A
Ethernet transceiver PHY firmware download failed.
Failed to init Eth Marvel PHY (error)>>>
So I think the ethernet interfacing sw isn't loading (Failed to init). Anybody have a opinion here?
After boot I have got some show commands to check the ETH status.
<<<#sh ip int brief
Interface  IP-Address      Method   Status                 Protocol   Speed      Duplex
wired0     192.168.224.131 static   up                     up         n/a        unknown
wired1     unassigned      unset    up                     up         1000       full
bvi1       unassigned      unset    up                     up         n/a        n/a
wifi0      n/a             n/a      administatively down   down       n/a        n/a
wifi1      n/a             n/a      administatively down   down       n/a        n/a >>>
Speed and duplex unknown on wired 0? Another sign of ETH malfunction.
#sh controllers wired 0
wired0    Link encap:Ethernet  HWaddr 78:72:5D:88:CB:78 eMac Status: DOWN
          inet addr:192.168.224.131  Bcast:192.168.224.159  Mask:255.255.255.224
          UP BROADCAST RUNNING PROMISC MULTICAST  MTU:2400  Metric:1
          RX packets:2127 errors:0 dropped:0 overruns:0 frame:0
          TX packets:316 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:80
          RX bytes:577433 (563.8 KiB)  TX bytes:47954 (46.8 KiB)
#sh contr wired 1
wired1    Link encap:Ethernet  HWaddr 78:72:5D:88:CB:79 eMac Status: UP
          inet addr:192.168.224.131  Bcast:192.168.224.255  Mask:255.255.255.255
          RX packets:348 errors:0 dropped:1 overruns:0 frame:0
          TX packets:112 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:81574 (79.6 KiB)  TX bytes:13507 (13.1 KiB)
Pinging from AP to PC
48ap01-pr#ping 192.168.224.132
Sending 5, 100-byte ICMP Echos to 192.168.224.132, timeout is 2 seconds
Success rate is 0 percent (0/5),
Pinging AP from PC
 ping 192.168.224.131
PING 192.168.224.131 (192.168.224.131): 56 data bytes
64 bytes from 192.168.224.131: icmp_seq=0 ttl=64 time=0.516 ms
64 bytes from 192.168.224.131: icmp_seq=1 ttl=64 time=0.573 ms
64 bytes from 192.168.224.131: icmp_seq=2 ttl=64 time=0.595 ms
64 bytes from 192.168.224.131: icmp_seq=3 ttl=64 time=0.802 ms
--- 192.168.224.131 ping statistics ---
4 packets transmitted, 4 packets received, 0.0% packet loss
round-trip min/avg/max/stddev = 0.516/0.621/0.802/0.108 ms
Show arp from AP
48ap01-pr#sh arp
        Address Age (min)     Hardware Addr
192.168.224.132         0 x:x:x:x:E6:C3
Show arp on PC
% arp -a
? (192.168.224.131) at x:x:x:x:cb:78 on en9 ifscope [ethernet]
I'd like to be wrong but I thing is a HW issue or corrupted SW.
Anyone have a suggestion?
Is there a way to start fresh like dowloading using something like ROMMON on other APs? but how if can get the thing to even ping.
15 Replies 15
DivakaranV
hi Dan - i knew this is a old thread and if you have fixed this already then good and ignore it. or try this if you still have this issue or with any other AP with same issue. try upgrade the code on the AP 4800 to ap3g3 15.3.3, jpj3 or something like that and then try to upgrade to me version. it should work. looks like you have some missing files in the storage which is throwing the error and that could happened during your incomplete earlier migration attempt. share your progress and updates. thanks
