05-27-2002 06:39 AM - edited 07-04-2021 11:12 PM
A customer needs to communicate his users via wireless in a plant. In this plant there are processes where explosive materials are used. The noise level is very high and vibration of the buildings is constant because of the machines on production. The building material is concrete and steel, all machines are stainless material. Do I have any problem using 2.4 Ghz spread spectrum in this environment? What do I have to be careful about in these conditions?
05-27-2002 07:27 AM
The fundamental issue is the molecule sizes in the particular explosives in use and the wavelength being used. Water molecules are the right size to dissipate 12cm waves (2.4GHz divided by the speed of light). That's why you get rain fade.
Your customer should have lab facilities available to determine the stability of their material in varying conditions. The short answer is that if the explosive cannot be excited (heated enough to trigger a reaction) in a microwave oven, it is not reacting to 2.4GHz (same used in microwaves) wavelengths at all.
2.4GHz is in use now in petroleum production facilities, but that precident is not enough to go on. You may need to test 2.4GHz, then 5.2GHz, then 5.8GHz and even 900MHz to find a license-free frequency that is safe for the facility.
Your inquiry may warrant further discussion.
Matthew Wheeler
Blue Modal
+1-866-2-UNWIRE
05-27-2002 07:57 AM
Actually I am going to follow your advise about testing in a lab with 2.4 Ghz or maybe the personnel in charge of that department already have those tests. The materials are related to perfume substances. I will let you know results.
05-27-2002 07:31 AM
I work at Cape Canaveral Air Force Station and just got finished deploying nineteen access points around a new launch facility. The process of securing engineering approval for deployment was extensive but the end results was good. In short, the actual explosive materials used are not affected by the 2.4Ghz signal but any electronic ignitors must be tested for signal influence.
05-27-2002 08:14 AM
Thanks for your message, I will let you know about my real site survey
Socorro Guerrero
