Issue setting Primary Controller IP Address on Prime 2.0
Willem de Groot
Hi all,
I have a problem with a AP template on Prime 2.0.
I have a WLC pair (7.4.121.0) setup as N+1.
Now on the Prime (2.0) I created a Lightweight AP Configuration Template, setting the Primary and Secondary Controller name (from Dropdown) and pasted the IP Addresses of these controllers to the appropriated fields.
I also set the AP Failover Priority to Medium.
That is all in the template.
Saved the template. Selected (the only) one AP on this WLC's to apply the template. hit Apply, status says "Success".
Checking the AP, the controllers and Failover Prio are set but the IPAddress fields are empty.
Back to the Prime template, the IP Adresses are set to 0.0.0.0 again.
Whats wrong here?
thanks
Willem
LAN Operations
I am also facing this trouble.. Can anyone have solution to this problem ??
Hi Cumminslan,
No, I do not have a solution for this.
