Issue with AP Auth List
nix-patheon
Hi guys,
I'm havin problems joining an AP (3602I) to my controller (5508) when authorising MIC's against against my auth-list on the controller.
I have added the AP MAC address to the auth-list but the AP won't successfully join. The controller occasionally says "joined" and I can view it in the AP list, but the AP status is always UNKNOWN, whereby I will reset the AP and try again.
Any ideas?
Thanks.
19 Replies 19
The X.509 certificates are burned into protected flash on both the       access point (AP) and WLC at the factory by Cisco. On the AP, factory installed       certificates are called manufacturing installed certificates (MIC).
You must select MIC box to connect AP to WLC.
For Auth for APs
you can add the mac address of APs and check the box  Autheriz  MIC APs againest auth-list or AAA.
Scott Fella
That's not increasing security. If someone out a new Cisco ap that is lightweight on your network.... It's your now, because you manage it.
-Scott
I thnk I see where I have went wrong. I need to check both boxes? One to allow the MIC, and the other to authorise against the MAC list?
Is the correct answer!
Correct answer is to Sandeep (the penny dropped after reading his post a couple of times), but thank you for your time Scott, it is very much appreciated.
Correct. Also note you can add your APs to the Ap policy list OR the mac address filter. Both will work,
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
"Im like bacon, I make your wireless better"
