11-24-2005 04:40 AM - edited 07-04-2021 11:22 AM
Since upgrading to WLSE 2.12 I've noticed that it's started doing a WLCCP authentication request via the WDS (AP-based) to our Cisco ACS 3.3.3 every 30 sconds without fail.
Is this a known bug or a new feature?
regards
Martyn
11-28-2005 09:50 AM
Are you positive it is the WLSE that is doing the request? Can you do the below and attach the output.
Go to the WLSE command line via telnet or SSH, login as admin, and use the following command:
dumptcp proto ip interface ethernet0 host
where
Usually this interaction is initiated by the WDS device.
Thanks.
12-02-2005 02:07 AM
02-24-2006 12:38 AM
I may have discovered what the problem is. On a recent posting (30 Jan 2006) called "WLSE WDS Authentication Issue" another user had problems with authentication of their WDS service. It would seem that I too may have been caught by bug CSCsb47726.
Because the authentication process is not quite working correctly, I suspect the WDS Access Point is trying to reauthenticate every 30 seconds to achieve "Security Keys Established" with the WLSE. At present it is only geting as far as "Authenticated".
This may also explain my problem with my WDS/WLSE/ Radio Management process not finding rogue access points since my recent upgrade to ACS 3.3.3 and WLSE 2.12.
I hope this helps others who may be in the same predicament.
regards
Martyn
