lightweight AP (3502i) is not joining with vWLC
sifathmirza
Hello Experts,
1.my lightweight AP(3502i) is not joining with virtual Wireless Lan Controller
my Ap is getting IP from DHCP , but it shows not joined  in wlc, can you please tell me what was the problem,
2.is it possible to  install new image in lightweight AP(3502i) .
* [Lightweight AccessPoint (3502I) Version 12.4(23c)JA5  "flash:/ap3g1-rcvk9w8-mx/ap3g1-rcvk9w8-mx"]
* Virtual Wireless Controller (8.2.100.0)
  Thank you .
Ravi Singh
Level 7
Level 7
Please check the below Troubleshoot guide
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/119286-lap-notjoin-wlc-tshoot.html
Sandeep Choudhary
Is it correct model name of AP ?
Please check and paste the output of this command from AP: sh version
From WLC: sh sysinfo
Don't forget to rate helpful posts
Sorry for late replay ,
APa44c.11d3.3ae9#sh version
Cisco IOS Software, C3500 Software (AP3G1-RCVK9W8-M), Version 12.4(23c)JA3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 18-Oct-11 15:02 by prod_rel_team
ROM: Bootstrap program is C3500 boot loader
BOOTLDR: C3500 Boot Loader (AP3G1-BOOT-M) Version 12.4(23c)JA5, RELEASE SOFTWARE (fc1)
APa44c.11d3.3ae9 uptime is 24 minutes
System image file is "flash:/ap3g1-rcvk9w8-mx/ap3g1-rcvk9w8-mx"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP3502I-E-K9 (PowerPC460exr) processor (revision A0) with 81910K/49152K bytes of memory.
Processor board ID FCZ1623W0UL
PowerPC460exr CPU at 666Mhz, revision number 0x18A8
Last reset from power-on
LWAPP image version 7.0.112.74
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: A4:4C:11:D3:3A:E9
Part Number : 73-12175-05
PCA Assembly Number : 800-32268-05
PCA Revision Number : A0
PCB Serial Number : FOC16175AYN
Top Assembly Part Number : 800-32891-01
Top Assembly Serial Number : FCZ1623W0UL
Top Revision Number : A0
Product/Model Number : AIR-CAP3502I-E-K9
Configuration register is 0xF
APa44c.11d3.3ae9#
*Apr 16 07:12:23.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.100.3.72 peer_port: 5246
*Apr 16 07:12:23.003: %LWAPP-3-CLIENTERRORLOG: Peer certificate verification failed
*Apr 16 07:12:23.003: %CAPWAP-3-ERRORLOG: Certificate verification failed!
*Apr 16 07:12:23.003: DTLS_CLIENT_ERROR: ../capwap/capwap_wtp_dtls.c:348 Certificate verified failed!
*Apr 16 07:12:23.003: %DTLS-4-BAD_CERT: Certificate verification failed. Peer IP: 10.100.3.72
*Apr 16 07:12:23.003: %DTLS-5-SEND_ALERT: Send FATAL : Bad certificate Alert to 10.100.3.72:5246
*Apr 16 07:12:23.003: %DTLS-3-BAD_RECORD: Erroneous record received from 10.100.3.72: Malformed Certificate
*Apr 16 07:12:23.003: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10.100.3.72:5246
*Apr 16 07:12:23.003: %CAPWAP-3-ERRORLOG: Invalid event 38 & state 3 combination.
from wlc
(Cisco Controller) >show ap join stats summary all
Number of APs.............................................. 2
Base Mac AP EthernetMac AP Name IP Address Status
67:58:34:01:00:00 N A N A 10.100.3.7 Not Joined
a4:4c:11:d3:3a:e9 N A APa44c.11d3.3ae9 10.100.3.7 Not Joined
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Build Name....................................... Engg Special Image
Product Version.................................. 8.2.100.0
RTOS Version..................................... 8.2.100.0
Bootloader Version............................... 8.2.100.0
Emergency Image Version.......................... 8.2.100.0
Build Type....................................... DATA + WPS
System Name...................................... Cisco_66:e5:93
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1631
IP Address....................................... 10.100.3.72
IPv6 Address..................................... ::
System Up Time................................... 0 days 0 hrs 30 mins 58 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... US - United States
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 2
Number of Active Clients......................... 0
Burned-in MAC Address............................ 00:0C:29:66:E5:93
Maximum number of APs supported.................. 200
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1
Licensing Type................................... RTU
vWLC config...................................... Small
