Loading Autonomous firmware to 1552E
servisturk
i got a problem with changing 1552e firmware to autonomous. i made many times other ap' s firmware change but now something wrong. i installed the tftpd server to machines it s working ok.image is :c1520-k9w7-tar.default. my pc ip address 10.0.0.2/24. pushing to reset button and release and 1552 loading default config. tftpd server doen t create any log. the ap i think doesn t look a tftp server. anyone has any idea about the issue? thanks.
15 Replies 15
Erwin Salazar
Hi Ilkay,
Were you holding the reset button down for at least 20-30 seconds? An easier way may be to console directly into the device and issue the following command through CLI:
debug capwap console cli
archive download-sw /force /over tftp:///.tar
Cheers,
Erwin
______________________________________
How helpful was I? Don't forget to rate me when you have the chance!
Cheers, Erwin ______________________________________ How helpful was I? Don't forget to rate me when you have the chance!
%Error opening tftp://10.0.0.2/c1520-k9w7-tar.152-4.JA1.tar (Timed out)
mostly i want to kick cisco products (:
servisturk
thanks erwin, i m trying to archive command but its giving error opening tftp server timeout. Tftp server open and running . Ap ping to tftp server. netstar -a saying port 69 ok. do you have any idea?
Sent from Cisco Technical Support Android App
servisturk
the ap, its not looking any tftp or ftp protocol. same error for both protocol.
Ilkay,
Is the tftp server pingable from the AP itself?  You may have to assign static address information if you are plugging the AP directly to your laptop:
capwap ap ip address
capwap ap ip default-gateway
Cheers,
Erwin
thx erwin, i did it still same...
Jacob Snyder
Level 5
Level 5
What TFTP server are you using? I know their are issues with Aironet APs and OS X built in Tftp server.
servisturk
here is the result when i was try downgrade from wlc :
%Error opening tftp://10.0.0.3/c1520-k9w7-tar.152-4.JA1.tar (Timed out)
archive download: takes 62 seconds
i upgraded the wlc ios over same tftp server. i want to hammered the fucking ap!!!
servisturk
hi everyone,
i have a new issue. my tftp server ping to wlc. wlc ping to tftp server. 1552e ping to wlc wlc ping to 1552e. here is the issue ap doesnt ping to tftp server and tftp server doen t ping to 1552e. anyone has any idea ?
servisturk
problem solved with the wlc 2504. but i have new advantures. cisco entertainment company. new issue here. i m configuring the ap but when i restart the ap configuration lost. cool huh!
Make sure the ap is in a REG state before you configure the AP.
-Scott
sorry scott i didn t update new issues resolve the configuration error with config.txt. now the ap not broadcast ssid...
here is the config :
! Last configuration change at 14:46:21 UTC Sat Sep 7 2013
version 15.2
no service pad
service password-encryption
hostname T-ISKELE
logging rate-limit console 9
no logging console
enable secret 5 $1$Ngui$7VOfhU.knttlfvsQSYkNw/
no aaa new-model
no ip cef
ip name-server 192.168.10.1
dot11 syslog
dot11 ssid AP1
   authentication open
   authentication key-management wpa version 2
   wpa-psk ascii 7 07192E484F0F160B121C0E1824787B757B
dot11 ssid ssid-string
   guest-mode
dot11 guest
username Cisco password 7 02250D480809
bridge irb
interface Dot11Radio0
 no ip address
 encryption mode ciphers aes-ccm tkip
 ssid AP1
 antenna gain 128
 speed  basic-1.0 2.0 5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
 station-role root
 bridge-group 1
 bridge-group 1 subscriber-loop-control
 bridge-group 1 spanning-disabled
 bridge-group 1 block-unknown-source
 no bridge-group 1 source-learning
 no bridge-group 1 unicast-flooding
interface Dot11Radio1
 no ip address
 ssid AP1
 antenna gain 128
 peakdetect
 no dfs band block
 speed  basic-6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
 channel dfs
 station-role root
 bridge-group 1
interface GigabitEthernet0
 no ip address
 duplex full
 bridge-group 1
interface GigabitEthernet1
 no ip address
 duplex full
 bridge-group 1
interface GigabitEthernet2
 no ip address
 duplex full
 bridge-group 1
interface GigabitEthernet3
 no ip address
 duplex full
 bridge-group 1
interface BVI1
 ip address 192.168.10.202 255.255.255.0
 ipv6 address dhcp
 ipv6 address autoconfig
ip default-gateway 192.168.10.1
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
 login local
 transport input all
end
i saw my mistake resolve the problem... (:
