01-13-2013 04:31 PM - edited 07-03-2021 11:20 PM
Hi everyone,
We need WiFi security on our corporate SSIDs locked down using certificates, we are using wlc cisco 2100 series. We need these on every workstation, laptops etc. Need help guys.
Kind regards,
Norman.
Solved! Go to Solution.
01-15-2013 02:30 AM
If you want to install certificates on the end devices (laptops, PCs...etc) to allow them for the wireless then you need to use EAP-TLS security method.
This guide should give you good information about it:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_white_paper09186a008009256b.shtml
Amjad
Rating useful replies is more useful than saying "Thank you"
01-16-2013 04:48 PM
Take a look at this doc
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a00807f42e9.shtml#auth-8201
01-13-2013 05:59 PM
Well... You will need a radius server that is hopefully also tied to you DC. This isn't really easy to explain how to do. There are many ways and it depends on your clients and what resources you have.
All I can say if you want to give this a try yourself is to search
WLC PEAP
WLC EAP-TLS
01-16-2013 02:24 PM
Hi Amjad, is this good on windows 7? If you can give me a documentation for this or step by step on how to configure this, much appreciated... one more thing, do I still need to configure group policy for the laptops?
01-16-2013 03:05 PM
GPO helps push out the wireless profiles to the Windows 7 machines and also certificates if you decide to use EAP-TLS. You would need a PKI infrastructure in order to do EAP-TLS or use certificates in general and a Radius server. Microsoft has IAS (2003) or NPS (2008). Cisco has ACS or ISE.
There isn't really a one document to help. You just have to search for various parts.
Windows 7 EAP-TLS configuration example
Windows 2008 NPS EAP-TLS configuration example
01-16-2013 04:42 PM
Hi scott, please have a look on my current config...
do I have to change something here?
regards,
Norman
01-16-2013 04:48 PM
01-15-2013 02:30 AM
Amjad
