MAC filtering - DHCP issue
gdevesco
Community Member
Hi all,i'm experincing some trouble about a 1100 access point and a/b/g cardbus adapters AIR-CB21AG-E-K9.The AP seems to work correctly with WLAN clients statically IP addressed, but the client doesn't obtain a DHCP address. Tried to disable MAC filtering, the problem disappears, but the policy of my customer is that the MAC filtering is to be enabled.Maybe i'm wrong,i've 3 client adapters and applied their MAC list to the radio interface. Here the AP config, can you help me ?
Giovanni
Using 2367 out of 32768 bytes
version 12.2
no service pad
service password-encryption
hostname ap
enable secret xxxxxxx
username xxx password xxxx
ip subnet-zero
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit xxxxxxxxxxxxxxxxxxxxxxxxxx transmit-key
encryption mode wep mandatory mic
ssid YYYYYYYYYY
authentication open
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.
54.0
rts threshold 2312
station-role root
l2-filter bridge-group-acl
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 input-address-list 700
bridge-group 1 output-address-list 700
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 10.236.8.10 255.255.255.0
ip access-group 101 in
no ip route-cache
ip default-gateway 10.236.8.1
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/ea
/ivory/1100
ip radius source-interface BVI1
access-list 101 permit icmp any any
access-list 101 permit tcp host 10.236.8.29 host 10.236.8.10 eq www
access-list 101 permit tcp host 10.236.8.29 host 10.236.8.10 eq telnet
access-list 101 permit tcp host 10.236.8.29 host 10.236.8.10 eq 22
access-list 101 permit tcp host 10.236.8.30 host 10.236.8.10 eq www
access-list 101 permit tcp host 10.236.8.30 host 10.236.8.10 eq telnet
access-list 101 permit tcp host 10.236.8.30 host 10.236.8.10 eq 22
access-list 101 deny ip any any
access-list 700 permit 0040.96a2.9077 0000.0000.0000
access-list 700 permit 0040.96a2.8be6 0000.0000.0000
access-list 700 permit 0040.96a2.907d 0000.0000.0000
access-list 700 deny 0000.0000.0000 ffff.ffff.ffff
bridge 1 route ip
line con 0
line vty 0 4
login local
line vty 5 15
login
kmarrero
Level 8
Level 8
The DHCP request is a layer 2 and layer 3 broadcast which you are filtering.
The server sends a DHCPACK response and it is a L3 broadcast and a L2 unicast as well. You need to allow UDP ports 67 and 68 through your ACL.
Thanks for your reply,Kyle.Sorry but i've not understood where i could allow those ports: i thought
that ACL 700 as configured is only to permit in input to the radio intf the traffic of the frames with the source and destination MAC of my wireless clients and L3 is not to be checked.I thought also that FFFF.FFFF.FFFF is to be passed, where i'm wrong ? (i'm new to L2 ACLs)
Thanks for your patience
Giovanni
