MAC Flaps from Wireless Network
Hello everyone!
I had this topic posted to another support forum but never got a response.  So I'm posting it here:
I'm  getting MAC flap notifications from 2 switches at our remote office  from the same two switches (switch 2 & 6).  There are a total of 7  switches (5 on the first floor & 2 on the second floor).  Each  switch connects to the root bridge with no redundant links.  There are 4  access points that are autonomous with two SSIDs; 2 of the APs are  connected to switch 2 (1st floor) and the remaining two are connected to  switch 6 (second floor).  The switchport configuration is as follows  which is the same at our main campus:
interface GigabitEthernet1/0/1
description *** WIRELESS ACCESS POINT ***
switchport mode trunk
switchport nonegotiate
speed 100
duplex full
macro description cisco-wireless
spanning-tree bpduguard enable
end
At  the main campus we have a 5508 WLC with 85 LAPs and we don't have this  issue.  My assumption at this point has to do with roaming since our  therapists have to move between both floors.  What's even strange is  that I can't find the mac (0013.0210.5344) of the device causing the  flaps when I run the command 'show dot11 assoc' from my APs.  All I know  based off the MAC is that it's an Intel WNIC.  Here is the config of  one of the APs at the remote office.  How can I get to the bottom of  resolving these MAC flapping notifications?
version 12.4
no service pad
service password-encryption
hostname pag1ap01
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone -0500 -5
clock summer-time -0400 recurring
ip domain name <DOMAIN>
ip name-server <DNS IP>
dot11 vlan-name default vlan 1
dot11 vlan-name dsl vlan 6
dot11 ssid pathwaysaironet
   vlan 1
   authentication open
dot11 ssid patnet
   vlan 6
   authentication open
   guest-mode
dot11 network-map
power inline negotiation injector 001a.6c7c.4882
power inline negotiation prestandard source
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 6 key 1 size 40bit <KEY> transmit-key
encryption vlan 6 mode wep mandatory
encryption vlan 1 key 1 size 128bit <KEY> transmit-key
encryption vlan 1 mode wep mandatory
ssid patnet
speed  basic-1.0 basic-2.0 basic-5.5 11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.6
encapsulation dot1Q 6
no ip route-cache
bridge-group 6
bridge-group 6 subscriber-loop-control
bridge-group 6 block-unknown-source
no bridge-group 6 source-learning
no bridge-group 6 unicast-flooding
bridge-group 6 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
speed 100
full-duplex
interface FastEthernet0.1
no ip route-cache
bridge-group 1
interface FastEthernet0.6
no ip route-cache
bridge-group 6
interface BVI1
ip address <IP ADDRESS> <MASK>
no ip route-cache
ip default-gateway <GATEWAY IP>
ip http server
ip http authentication aaa
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community snmpsux RO
bridge 1 route ip
line con 0
line vty 0 4
sntp server <SNTP IP>
sntp broadcast client
end
Yes,  we're not using the most secure encryption on the wireless and that'll  be changed but I need to resolve the flapping issue first.  You're help  is greatly appreciated.  Thanks!
Terence
No wonder why u have issues:-) Try setting this as 1,6,11 and 1 where first channel 1 and last channel 1 AP's are far apart physically.
Hope that helps.
Najaf
Please rate useful posts
12 Replies 12
kcnajaf
Level 11
Level 11
Hi Tereace,
Is this Mac flapping causing any trouble for you?
It is very normal on switch to display this mac flapping message if APs are connected to the switch port. The reason for this is due to the fact that switch learns of a particular clients mac from one particular port to which the AP (assume this is AP01)is connected to. Now when the wireless client roam to other AP( assume AP02 which is connected on a different port of same switch where AP01 is connected) the switch will learn that same MAC address on a different port I.e AP02's port and displays the mac flap message.
If u check show dot11 asso on all AP's I'm sure that u will be able to trace the MAC address which is flapping.
Hope that helps
Najaf
Najaf,
We have had some complaints about some wireless issues and I'm not sure if this is causing those problems.  However, other than that, the only trouble it's causing is syslog messages which isn't a technical or performance issue.  I was hoping to find out if I can configure local & client power as well as static channel assignments will fix the problem.
Terence
As far as I have seen so far this doesn't create any performance issue with wireless. I agree that this will generate syslog message which is not much relevant.
What sort of wireless issue has been reported from the site? Most likely the issues would have been caused by channel inference but it will be difficult to say it for sure unless u perform a site survey.
Najaf
Today was the first day I was able to get over to this office and perform a quick site survey.  From my findings it looks like channel interference may be the cause of complaints about drops, etc.  I'm going to set the channel assignments manually and set the AP/Client local power and see if that helps.
This are autonomous AP's right? Are they not using manual channel assignment now?.
Najaf
Based on that running config of one of those autonomous APs I posted they're not manually set.
Running config mostly likely will not show you the channel setting I would assume. You could check what channels AP's are running with show cont dot110 and verify is they are on non overlapping channels.
Najaf
They are definitely overlapping.  They are within the 10-20% overlap range of where they're physically placed and the channels are currently 1, 3, 7, and 9.
Hope that helps.
Najaf
Actually,
I've just done that before you replied.  I'm gonna conduct a quick site survey and see what happens but I think this will resolve most, if not, all the issues.  Thanks!
Thanks for using the rating...
Let us hope for the best with your wireless issues 🙂
Najaf
Terence,
To avoid channel interference keep same channel aps atleast 20dBm apart. That means take a laptop with softwear that reads dBm, not bars. Stand next to your AP on channel 1. Say you get a 50 dBm (RSSI). Your next ap you hear in that same channel should be at 70 dBm (RSSI).
Make sense?
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
