Macbook Pro and using LEAP
ggladney
Level 2
Level 2
We are staring to get Macbook Pros and when I tried to configure the Airport Extreme interface to use LEAP, it fails. Was wonder if anyone else has seen this with the Intel Macbook Pro. Using Airport Extreme on the PowerPC Macbook and other Mac type laptops seems to work fine.
Gary
klmueller
Frequent Visitor
Frequent Visitor
I just started using a MacBook pro and am having a similar issue. Were you ever able to figure out a solution to this issue?
Thanks.
- Klaus
ggladney
Level 2
Level 2
What I did, configure the access point with
authentication open eap eap_methods
authentication network-eap eap_methods
It used to work with just EAP and I started having problems with MacBook Pro connecting using LEAP. This fixed the problem I had.
Gary
cjs226
Community Member
I was able to connect via LEAP with my Intel MacBook at a previous employer's so I know it can be done - if that helps.
cjs
