machine-authentication with digital certificate
hstf_techy
https://kb.meraki.com/knowledge_base/radius-configuring-peap-mschapv2---machine-authentication
RADIUS: Obtain a digital certificate for a Windows domain member system
I am reading the above article and I am wondering do I need to obtain a certificate manually for each computer?
there should not be, unless you are doing a CRL and checking your CA for updates.  So long as your the client trusts the AAA server certificate you should be fine.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
Stephen Rodriguez
no, you do not need to do it manually.
http://technet.microsoft.com/en-us/library/cc731242.aspx
HTH,
Steve
HTH,
Steve
Thanks.
Let say if they are enroll automatically, is there any affect with the authentication process if the PKI server is down?
HTH,
Steve
HTH,
Steve
Abhishek Abhishek
As per your query i can suggest  you the following solution-
No, there is no need to obtain a certificate manually for each computer.
Hope this will help you.
