Management Gateway Failover // WLC 5520
Hello guys,
I have a question and I would like someone to give me visibility on how the management gateway failover works.
What would be the normal behavior of having this feature enabled or disabled for a Wireless network with HA SSO?.
The Cisco documentation does not explain this feature or at least I have not found any information yet.
Just check the link for HA SSO Deployment Guide
Hope this clarify your quires.
Sathiyanarayanan Ravindran
Please rate the post and accept as solution, if my response satisfied your question:)
Thank you. The document does not clearly explain the operation of Management Gateway Failover.
Wifi_Eshwar92
if the Management interface gateway is unreachable, then this setting can help in triggering HA.
config redundancy management-gateway-failover [enable/disable]
