Managing WLAN only in a specific Ap-Group.
severi
I would like to schedule the enable or disable of a specific WLAN only in a specific AP-Group.
Is possible to do with a Prime?
Regards.
Mirko Severi.
Scott Fella
I don't think that is possible, since the WLAN has to be enabled/disabled on the WLAN itself.  Ifyou don't see a setting on the AP Group to do this, then there is no way PI can do this also.  Here is an older doc with WCS scheduling you can still do in Classic Theme:
https://supportforums.cisco.com/document/58081/managing-wireless-lan-status-schedules-automatic-enabledisable-feature
Scott
-Scott
Scott Fella
The only way you can possibly get this to work is to create a template (scheduled) to remove the WLAN from the AP Group and add the WLAN back to the AP Group.  Kind of a cowboy way to do things, but that might work for you.
Scott
-Scott
