Max concurrent logins
juan_cye_ccna
Level 4
Level 4
i need that wlc lets only one session login for user, it means if someone use auth data, user: john, password: cisco123 and another person knows this same information, the wlc doesn´t let that he or she is connect to network because it there is already a "right" user logged in. This works fine if i configure one SSID with web authentication, but i haven´t made it when i configure SSID with wpa2 (enterprise) + 802.1x (RADIUS). Can i reach this?
Thanks.
5 Replies 5
Scott Fella
On the wlc security tab there is a login policy for concurrent login. You can set that to 1.
Scott Fella
Sent from my iPhone
-Scott
Hi Scott,
thanks for your response.
how i have said it, "max concurrent logins" set to "1" works fine in SSID with web auth but this doesn´t work it other user are connected through SSID with WPA2 + 802.1X (RADIUS + Active directory).
I think that with web auth ( wlc local net users), wlc has a control to users who have got access, but when auth is done through AD the wlc doesn´t and of course in this SSID configuration i couldn´t make my objective to limit user logins. Am i right?
Well if that doesn't work, the only way is on the radius server you are using.  I know that Cisco ACS has a concurrent login you can set.  I don't think IAS or NPS does.
-Scott
Scott,
thanks for your help. I think the same. I asked to administrator that he reviews ACS configuration.
The only thing is... If the wrong person logins first, the person who actually needs to login will not gain access.
-Scott
