03-11-2009 12:34 PM - edited 07-03-2021 05:17 PM
Wich's the max. count of clients 802.11b/g in a AP 1130
I have a Thresholds Template with a Max client of 12, witch's the max count of clients that can support it.
Solved! Go to Solution.
03-11-2009 03:39 PM
Define "help"? The more the number of clients associate to an AP, the slower the bandwidth through-put.
It will help you financially, but performance-wise? I don't think so.
03-11-2009 02:07 PM
There's no hard number that the AP can support. Cisco recommends no more than 25 clients per AP, but the AP will associate as many clients as possible without a restriction.
03-11-2009 03:16 PM
I have 24 clients righ now, Does it help me if i increase the Load Thresholds, Max Clients to 24 ?
03-11-2009 03:39 PM
03-11-2009 06:46 PM
The default is 12, but the wlc will have that AP send beacons to the try to have the devices associate to another AP will less than 12 devices. If the devices do not associate with another AP, then they are allowed to associate.
Changing the threshold will only change the way you get alerts from the wlc. If users are not complaining, then 24 users on that AP is fine. What they use the wireless for will determine how many users you can have per ap. Observe the users or associate to that ap also and see for yourself if you think its slow. It all depends on what applications you are using on the wireless.
03-12-2009 10:54 AM
thaks a lot for u reply, it was helpful.
