07-09-2006 05:20 AM - edited 07-04-2021 12:34 PM
I've hit a maximum of SSC in my controlers. (509) Is there any plan to bring that number up?
07-10-2006 09:33 AM
Dominic,
Go into Security>AAA> general. change your database size from 512, up to 2048, save and reboot the unit.
07-10-2006 01:52 PM
Is there any way to get the SSC list from the controler with the CLI. My SSC are splitted over different controler and I want to merge them.
07-10-2006 02:19 PM
you can do a show auth-list. this will show you the mac adn ssc hash. Also, if you have WCS, you should be able to refresh the config, and pull it from there as well.
