Merak wireless controller
Matthew_1
Visitor
Hi all
Is it possible that we can use Meraki MX as an wireless controller or we need to add a wireless controller to manage AP's
p.s there is only 5 ap's
Not as a controller in the traditional way. The APs are always managed from the cloud. But you can add an MX to terminate your WLANs similar to the DMZ Anchor Controller in the Catalyst WLAN world.
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
